Home » Sponsored » Pi Speakers » Madison Knight 10" in SpeakerBox says 366L right?
Re: a little help [message #41909 is a reply to message #41908] Sat, 12 July 2003 19:34 Go to previous messageGo to previous message
366 liters for a 10" driver? oooo.... thats really big
As you go through pi aling enter the following fields
description= anything you want to call it
Type= M
lo cut= 50 (if you have 70hz sub 50 would be good)
hi cut= press enter for no entry
Eff= spl 1w/1m
power= watts max
impedance= Re (4,8,16 might get you close)
quantity= number of drivers per enclosure
for pi align you need to know from the t&s parameters
Vas this will be the VAD input (must convert to Cubic Feet)
Qts 1 devided by the Qts will be the QD input 1/.578=1.7301
Fs this will be the FD input
Enclosure type= B ( for bass reflex)
Port= C / cylinder R / rectangle
you now have all the dimensions and volume in cubic feet acording to pi align.
Bill
Previous Topic: JBL2226H+MAC40s+large room=Kick ass
Next Topic: Pi theater 3 or 4 and Adire 12.1
Current Time: Thu Oct 29 06:07:04 CDT 2026
