Home » Sponsored » Pi Speakers » Hi Bill and others. I think I've got it fixed now :-) Plz check!
Re: Hi Bill and others. I think I've got it fixed now :-) Plz check! [message #41849 is a reply to message #41844] Wed, 09 July 2003 12:01 Go to previous messageGo to previous message
Hi Adrian,
You should have no problems making a removable back to the cabinet that wont rattle or leak. Use a small rubber or foam gasket around the wood strip that the back is going to screw into. A cross brace that the back screws into will also be helpfull. You dont wanty the entire back panel to be unbraced or it will be a drum head.
Bill
Previous Topic: :-)
Next Topic: Cherry Pi Photos
Current Time: Thu Nov 05 21:12:41 CST 2026
