Home » Sponsored » Pi Speakers » Crossover values for Drivers with different Impedance??
Re: are your 288's a matched pair? [message #41831 is a reply to message #41828] Tue, 08 July 2003 05:23 Go to previous message
If they are like most of the "pairs" of altec drivers I've seen, the diaphrams will not even be from the same years, sometimes not even the same part #!? With used CD's, I prefer to replace the 'phrams with KNOWN good oem ones from Bill at Great Plains(source for Iconics production parts). And of course, you would obtain the CORRECT 8 ohm ones:) A benefit of new 'phrams will be that the freq. response characteristics on the left and right will be much closer to each other.
Yes, you could add a resistor to either driver to make the Z's the same, but a series R to the woofer will KILL your amplifier damping ability and throw away 1/2 the LF energy as HEAT, while a shunt resistor will merely drop the HF driver by 3dB while blowing off 1/2 the HF energy. INEFFICIENT as hell. And a waste of good components. You can always rework the HF crossover values for the 16 ohm HF Z, why exactly is THAT such a forbidding prospect in the first place? Sam
Previous Topic: 4 Pi Construction Question
Next Topic: How well does baltic birch finish?
Current Time: Fri Nov 06 00:45:20 CST 2026
