Home » Sponsored » Pi Speakers » making freq. response graph
Re: making freq. response graph [message #41775 is a reply to message #41774] Tue, 01 July 2003 15:37 Go to previous message
You're right that if you want to have an automatic process then you'll need a mechanism that synchronizes the generator sweep with the measurement device. You could have your computer D/A generate the sweep and read it with its A/D. Then synchronization would be a matter of timing logic in your code. Alternately, if your signal generator has some sort of synchronization signal, perhaps you could read it programmatically. Either way, you'll need to have a mechanism in place.
Previous Topic: 511B update #3 Major Improvement!
Next Topic: Low distortion op-amp
Current Time: Wed Oct 21 11:49:02 CDT 2026
