Home » Sponsored » Pi Speakers » wedge for corner horns
Re: wedge for corner horns [message #41650 is a reply to message #41648] Tue, 17 June 2003 15:02 Go to previous message
This wedge is a good idea, but surprisingly, you'll find that it doesn't make a noticeable difference. I used this exact sort of reflector in early prototypes and for the same reason you suggested - It would appear to direct on-axis sounds better. But I found no difference when I installed such a wedge.
Check out John Sheerin's wave mapping animation. It shows the movement of a wavefront past reflectors such as these.
Previous Topic: triamp Q for Wayne
Next Topic: help for crossover
Current Time: Wed Nov 04 03:22:53 CST 2026
