Home » Sponsored » Pi Speakers » triamp Q for Wayne
Re: Proper horn for 902/500Hz Xover [message #41643 is a reply to message #41642] Tue, 17 June 2003 04:35 Go to previous messageGo to previous message
AstroSonic is currently offline  AstroSonic
Tom,
Thanks for the info. I have 511B's and am wondering what the lowest acceptable crossover frequency would be for 'civilized' home use (no earthquakes, etc.). If the 511B's are not good to 500 Hz, which horns would you recommend? I would like to stick with 1st or 2nd order because I suspect that the more complex networks will be more difficult to optimize, and simpler is often times better.
Regards,
AstroSonic
Previous Topic: Concern frequency response 16Khz?
Next Topic: wedge for corner horns
Current Time: Thu Nov 05 13:28:11 CST 2026
