Home » Sponsored » Pi Speakers » 511B Update (#2)
Re: Deadening the 511B [message #41633 is a reply to message #41620] Mon, 16 June 2003 05:25 Go to previous messageGo to previous message
Hello,
By silastic bonded, do you mean that instead of just a metal weld, there is some rubbery stuff between the vanes? if so, my current set of 511bs have this feature. My spare "experimenting" set I wil have to look at, I didn't realize there was a difference. If they are hard welded I think I will mount them up and see what problems they have compared to my "rubberized" (hopefully silastic) set. Thank you for the info. I assume that since there is rubbery stuff inthere, this version has already been cut as others suggest?
Thanks again,
Russellc
Previous Topic: Ohm rating for 2 Pi Tower?
Next Topic: Speaker Building Update
Current Time: Thu Nov 26 10:40:26 CST 2026
