Home » Sponsored » Pi Speakers » 511B Update (#2)
Re:Use a sawzall [message #41623 is a reply to message #41622] Sun, 15 June 2003 11:23 Go to previous messageGo to previous message
You and my brother (plumber) would be great buddies - You're a fitter or boiler maker, right? My brother does everything with a sawzall except carve the Thanksgiving turkey. He's always saying "It says SAWS ALL don't it?"
While you and he may be artists with a sawzall, I certainly am not. I know I could part the webs with a hacksaw blade in one of those "jab saw" holders too, but neat it wouldn't be.
OTOH, A couple of years ago I needed to trim down a brass kickplate to fit the narrow bottom rail of my front door. I didn't think I could cut it very well, so I took it to a local shop asking them to take a couple inches off of it. I figured they'd put it in a shear and lop it off. They cut it freehand in a band saw - I could have done as well with a chainsaw. I spent an hour squaring the ragged edge with a flat mill file, the plate clamped bewteen pieces of angle iron as a reference.
Upon reflection, maybe a sawzall is the way to go....
Previous Topic: Ohm rating for 2 Pi Tower?
Next Topic: Speaker Building Update
Current Time: Thu Nov 26 10:40:36 CST 2026
