Home » Sponsored » Pi Speakers » Question for those who know!
Maybe a wide dispersion wood horn? [message #41576 is a reply to message #41570] Mon, 09 June 2003 16:01 Go to previous messageGo to previous message
I just thought of a sweet idea. You're very good with woodworking, so maybe you can make your own horn out of wood. The side pieces are easy because they're essentially straight but with the entrance radiused to match the throat angle from the copmpression driver. This angle sets the horizontal pattern. The top and bottom pieces can be exponential or tractrix curves, making a radial horn, or they can be straight forming a conical flare. Either way, radius the entry to match the throat exit angle and you might want to radius the mouth edge too.
Previous Topic: PSD2002-8S drivers available $80/pr
Next Topic: One & Two pi coil question.
Current Time: Fri Oct 23 22:42:47 CDT 2026
