Home » Sponsored » Pi Speakers » Need an educated guess from someone more knowledgable:
π cornerhorn using TAD 1602 [message #41543 is a reply to message #41541] Wed, 04 June 2003 14:45 Go to previous messageGo to previous message
If you go any bigger than 4ft3 with the TAD 1602, you'll need to make an EBS alignment. That's a good option - especially for a subwoofer - but it does mean your output below 100Hz is generated at reduced levels, in a reduced "shelf." That's why the alignment has the name - the response is extended but at a reduced "shelf."
I suggest using a π cornerhorn configuration, which generates prodigious bass using a motor chamber of 3.85ft3 tuned to 38Hz.
Previous Topic: New Speaker with Deltalite
Next Topic: Help pleaaase!
Current Time: Tue Nov 24 21:21:28 CST 2026
