Home » Sponsored » Pi Speakers » New Speaker with Deltalite
Re: New Speaker with Deltalite [message #41538 is a reply to message #41537] Wed, 04 June 2003 11:36 Go to previous messageGo to previous message
Midwoofer response above 1.6kHz is greatly attenuated by the crossover so I don't expect any peaking at 2.5kHz, if the appropriate Zobel is used. However, running this network without a Zobel will introduce a midrange peak, so you'll notice the difference when you install it.
Top-octave compensation as is described in the crossover document is intended for use only with compression horns that rolloff at high frequencies. I understand that your network is setup for only 2dB, so that's practically nothing, but I wouldn't suggest this kind of passive EQ with ribbons.
Previous Topic: Oh, I like that!
Next Topic: Need an educated guess from someone more knowledgable:
Current Time: Sun Nov 01 19:50:15 CST 2026
