Home » Sponsored » Pi Speakers » Suggestions for horn sub needed
how about Pi 7-18? [message #41490 is a reply to message #41489] Sat, 24 May 2003 21:47 Go to previous messageGo to previous message
Triodeuser is currently offline  Triodeuser
Thanks Wayne, for your response.
For placement, I'm probably ok on one side - there is a five foot window that has shutters - probably not great but hopefully OK if shuttered
I just might be OK on the side where the French doors come in - If I leave one of the French doors closed I'm getting the dimensions I need on two sides and almost on three - if there is an imperfection in the layout of one of the three sides does it kill the effect you're looking for completely or just make it sloppy?
Do you have anything you can send me that has the dimensions and set up of a Pi 7-18??
Thanks
Ken
I am
goodies
at
charter
dot
net
Previous Topic: Compression Drivers arrived !!!
Next Topic: Theatre 7 cornerhorns
Current Time: Sat Nov 28 19:41:50 CST 2026
