Home » Sponsored » Pi Speakers » Eminence horn
Re: pull the h290's [message #41461 is a reply to message #41460] Fri, 23 May 2003 05:36 Go to previous messageGo to previous message
Hey Sam....
I've read the reference to the Eminence have more extention on the top end many times on the Pi forum yet when comparing at least the published specs it appears the 2421 actually goes a little higher? I guess it will be a try it and see deal. As far as using the H290 horn it's just a matter of using the parts I have on hand. I do have a set of 2345's which can play down to 800Hz but they are much larger than the H290, not a big deal in itself , it's just that they won't the present cabints. You know how this hobby works, anyway I'll post my impressions after I do some experimenting.
THX Kelly
Previous Topic: crossover doc
Next Topic: JBL vs. Lambda??
Current Time: Thu Nov 05 01:52:39 CST 2026
