Sponsored
Eminence horn
Re: pull the h290's
message #41460
is a reply to
message #41457
Fri, 23 May 2003 04:49
Sam P.
May 2009
and install jbl 2370a flares, and "all will be well". The 2421's MAY not have the HF extension you need, look at the specs on the jbl site regarding their F10 at the top to be sure. Sam
Message index
Eminence horn
By:
LuxmanLover
on Thu, 22 May 2003 15:01
Damping and crossover filter Q
By:
on Thu, 22 May 2003 16:15
Re: Damping and crossover filter Q (or lost in Saskatoon)
By:
LuxmanLover
on Thu, 22 May 2003 16:38
Use of a horn under Fc
By:
on Thu, 22 May 2003 20:53
Re: pull the h290's
By:
Sam P.
on Fri, 23 May 2003 04:49
Re: pull the h290's
By:
LuxmanLover
on Fri, 23 May 2003 05:36
Re: why not x at 1kHz?nt
By:
Sam P.
on Fri, 23 May 2003 08:26
By:
LuxmanLover
on Fri, 23 May 2003 14:31
1kHz crossover values
By:
on Fri, 23 May 2003 15:28
crossover doc
JBL vs. Lambda??
Wed Nov 04 12:20:54 CST 2026
