Home » Sponsored » Pi Speakers » Eminence horn
Damping and crossover filter Q [message #41456 is a reply to message #41455] Thu, 22 May 2003 16:15 Go to previous messageGo to previous message
You should never operate a tweeter horn below it's cutoff because the compression driver will be unloaded. This will allow the diaphragm to move back and forth much further than it was intended at even low power levels and can damage the driver. Output will also be reduced below cutoff, so it will probably sound bad for that reason too.
Beyond the basic crossover function, the tweeter section of the π crossover does a few things:
1. It attenutates the region from the crossover point for two octaves.
2. It begins to remove attenuation two octaves above the crossover point to add HF augmentation.
3. It provides specific damping in the crossover region so that the response curve is neither peaked (underdamped) or too rolled-off (overdamped).
Previous Topic: crossover doc
Next Topic: JBL vs. Lambda??
Current Time: Wed Nov 04 12:21:05 CST 2026
