Sponsored
Eminence horn
Eminence horn
message #41455
Thu, 22 May 2003 15:01
LuxmanLover
May 2009
What is the effect/result of having your crossover less than the resonance of a given horn ie. using a 800hz crossover on a H290 horn.
Kelly
Message index
Eminence horn
By:
LuxmanLover
on Thu, 22 May 2003 15:01
Damping and crossover filter Q
By:
on Thu, 22 May 2003 16:15
Re: Damping and crossover filter Q (or lost in Saskatoon)
By:
LuxmanLover
on Thu, 22 May 2003 16:38
Use of a horn under Fc
By:
on Thu, 22 May 2003 20:53
Re: pull the h290's
By:
Sam P.
on Fri, 23 May 2003 04:49
Re: pull the h290's
By:
LuxmanLover
on Fri, 23 May 2003 05:36
Re: why not x at 1kHz?nt
By:
Sam P.
on Fri, 23 May 2003 08:26
By:
LuxmanLover
on Fri, 23 May 2003 14:31
1kHz crossover values
By:
on Fri, 23 May 2003 15:28
crossover doc
JBL vs. Lambda??
Thu Nov 05 01:50:36 CST 2026
