Home » Sponsored » Pi Speakers » Corner horn question
Corner horn answer [message #41422 is a reply to message #41420] Sun, 18 May 2003 23:44 Go to previous message
You actually don't want walls that are rigid. I know that's counter-intuitive, but the fact is that rigid walls cause sharp room modes. Having some panel flex in the walls and insulation behind them helps damp the room, much like having built-in bass traps.
Previous Topic: Power Handling of Pi Crossover
Next Topic: Altec 511B Ringing Update
Current Time: Wed Nov 04 08:05:21 CST 2026
