Home » Sponsored » Pi Speakers » Power Handling of Pi Crossover
Re: Power Handling of Pi Crossover [message #41412 is a reply to message #41409] Sun, 18 May 2003 13:45 Go to previous message
Power handling is determined by the limits of the components used. Coils and resistors are rated in maximum current and capacitors in maximum voltage. So you can get whatever size you need.
Check the π crossover document for more information. Pages 67-80 are specifically about power handling, and illustrate the requirements of each component with voltage curves.
Previous Topic: Baffle spacing, phase angles and time alignment, revisited
Next Topic: Corner horn question
Current Time: Wed Nov 04 10:06:17 CST 2026
