Home » Sponsored » Pi Speakers » Cornerhorns, revisited
Re: Questions to Michaelz [message #41381 is a reply to message #41375] Wed, 14 May 2003 16:48 Go to previous messageGo to previous message
Michaelz is currently offline  Michaelz
What driver(s) do you use?
What are the dimensions of the box(es)?
Are you using reflex or (as it appears) closed box - & do you use any electronic equalisation/compensation?
It's a square box with one corner cut off. The square sides are 2' long, based on this is the rest of the dimensions . The closed box serves as the back chamber of the horn. The driver is JBL2245. Basically, the volume in the cone of the driver for front chamber, with the corner piece (deflector), the space between the box and the deflector makes for the horn throat. I use Behringer 3400 for active crossover, no equalisation yet.
Previous Topic: JBL "drivers" are really fast!!
Next Topic: Pi Speakers Crossover SPICE values
Current Time: Tue Nov 17 21:41:58 CST 2026
