Wayne Parham Messages: 19101 Registered: January 2001
If the speaker were a purely resistive 8 ohm load, then an 8 ohm resistor in series would be perfect. It's simple and it would pad the speaker 6dB. But since the speaker is not purely resistive and has reactive properties, a series resistor will change the characteristics. If there is series capacitance, it will change the Q of the crossover filter and tend towards peaking. So you might want to include some shunt resistance to counteract this tendency. One could check it all out in Spice, but I think you would be safe with the general-purpose values of 4 ohms in series, followed by 8 ohms in shunt, across the midrange.
