Home » Sponsored » Pi Speakers » Damping 511B ringing: Whats your experience?
Re: more on fin cutting [message #41264 is a reply to message #41256] Thu, 08 May 2003 10:09 Go to previous messageGo to previous message
AstroSonic is currently offline  AstroSonic
TDC,
I am pretty much convinced that fin cutting will be a part of my 511B ringing control plan. Sam P. (below) also did this and reported good results. He used a sawzall and needed to make several cuts per fin to remove enough material. How did you cut them and what tool(s) did you use? Any hind-site observations greatly appreciated.
Good idea using the radial tire matrerial (to damp radial horns!). In as much as I do play some blues and rock on my system, perhaps I should use material from off-road radials.
Regards,
AstroSonic
Previous Topic: Where can I Buy some nice BIG CD horns???
Next Topic: MAF photos
Current Time: Thu Nov 05 08:10:58 CST 2026
