Home » Sponsored » Pi Speakers » hf response of 2226H vs. 2226J
Re: Top-octave compensation [message #41202 is a reply to message #41201] Fri, 02 May 2003 11:11 Go to previous messageGo to previous message
If you go down in capacitance value, the top-octave compensation will start higher and be less. The 0.47uF cap is just about perfect on the 010 crossover for the PSD2002. For the JBL 2426, it's better on the 012 and 014 models, and the bypass on the 010 version could stand to be slightly larger, about 0.55uF if I recall. When I had your 1602's, I used them with 4001's. I never used 2001's, so this is speculation, but I'll bet you're on the right track. A tiny bit less capacitance might be better for the 1" TAD's.
Previous Topic: Theater 4 Pi + .5mh in woofer circuit... Wayne ?
Next Topic: 10 Pi question for Wayne
Current Time: Tue Oct 20 08:57:15 CDT 2026
