Home » Sponsored » Pi Speakers » HF Horn-Woofer phase at crossover
Re:Radical DeStressing 511B's [message #41195 is a reply to message #41191] Fri, 02 May 2003 04:27 Go to previous messageGo to previous message
AstroSonic is currently offline  AstroSonic
Hi Sam,
Thanks for the info. I was able to locate Altec AN-9 at the Sound Practices website as you had suggested. The method of achieving acoustic alignment by changing the relative position of the drivers while wired in phase to produce a maximum null at the crossover, then reversing the driver phase (for 2nd order xover) is ingenious.
Now about destressing the 511b's... Just how much sawing/weld removal are we talking about? Just the fins, fins and flare, or the entire horn?
Regards,
AstroSonic
Previous Topic: "B" sides
Next Topic: Theater 4 Pi + .5mh in woofer circuit... Wayne ?
Current Time: Wed Oct 14 19:33:50 CDT 2026
