Home » Sponsored » Pi Speakers » Theater 4 Pi + .5mh in woofer circuit... Wayne ?
Re: Theater 4 Pi + .5mh in woofer circuit [message #41187 is a reply to message #41186] Thu, 01 May 2003 12:58 Go to previous messageGo to previous message
Neo is currently offline  Neo
Yes... I used the Zobel damper. That's the 20uf with 8 ohm resistor in parallel with the woofer... right ?
I read your presentation "Crossovers 101", the one you gave at the Mid-West AudioFest(I planned on going... but had to cancel). It seems to build the Theater 4 Pi cross-over a step at a time. I loved the graphs. Thanks for all your work.
I noticed one graph increased either the zobel cap or the 20uf cap in parallel with the woofer (I don't have it in front of me) and the graph seemed to antenuate to mid-range too. Would that be another/better way ?
Thanks...
Tom
P.S. I have 'ringing' in my ears. Maybe that makes me sensitive to a prominant high mid-range ?
Previous Topic: HF Horn-Woofer phase at crossover
Next Topic: hf response of 2226H vs. 2226J
Current Time: Sat Nov 28 18:41:45 CST 2026
