Home » Sponsored » Pi Speakers » Theater 4 Pi + .5mh in woofer circuit... Wayne ?
Re: Theater 4 Pi + .5mh in woofer circuit [message #41186 is a reply to message #41184] Thu, 01 May 2003 11:43 Go to previous messageGo to previous message
You may have conditions in your room that make the midrange a little "throaty." Adding a series coil would tend to attenuate the midrange - If used with a Zobel, it will introduce an additional first-order low-pass pole and if used without, a broadband attenuator that works throughout the vocal range.
Did you use the Zobel woofer damper?
Previous Topic: HF Horn-Woofer phase at crossover
Next Topic: hf response of 2226H vs. 2226J
Current Time: Sat Nov 28 18:41:43 CST 2026
