Home » Sponsored » Pi Speakers » Valvestate problem
Re: Valvestate problem [message #41109 is a reply to message #41105] Tue, 22 April 2003 11:42 Go to previous message
AmpKiller is currently offline  AmpKiller
Hi Wayne!
Thanks for your info! I'll check the tube soon. I just opened the amp (I was out of use for at least 2 years) and found some cables in very bad condition. One of the guesses I got was about a bad connection which somehow was fixed after shorting the circuit with the speaker cables. I'll repare the cables and see what happens, if it still does not work I'll check more bad connections and the tube.
Thanks a lot for your help!! I'll post the results here.
Best regards,
Jose
Previous Topic: 1Pi problems
Next Topic: Wayne -- anyone? Dual ducted vents possible w/Pi Alignment?
Current Time: Sat Oct 31 22:02:58 CDT 2026
