Home » Sponsored » Pi Speakers » Pi 18 in Bim finished
Re: "sensitivities of subsystems" [message #40940 is a reply to message #40935] Fri, 11 April 2003 20:29 Go to previous messageGo to previous message
I think Sam is right. I suggest changing the R1/R2 values and possibly omit the C1 component altogether. Your tractrix horn has collapsing directivity which provides some acoustic EQ. My crossover is designed for CD horns and provides electrical EQ to compensate for falling power response. So your speaker has twice the compensation, one in the crossover and another in the collapsing DI from the tractrix horn beaming at HF. The speaker isn't the same as designed, and I think the solution is to modify the R1/R2/C2 values as appropriate for the horn used.
Previous Topic: 4 Pi Theatre Questions . . .
Next Topic: how's the "room"
Current Time: Thu Nov 19 08:01:52 CST 2026
