Home » Sponsored » Pi Speakers » Suggestions for which Pi 7's to build
Re: Suggestions for which Pi 7's to build [message #40922 is a reply to message #40921] Wed, 09 April 2003 19:41 Go to previous messageGo to previous message
wasteh202 is currently offline  wasteh202
I will respond first. Take this with a grain of salt because I do not own either speaker.... but if I was making the decision that you are talking about I would go with the Theater 7.
I will probably next build the Theater 4, Theater 7 or the 10 folded horn. I would like to build a folded horn (just because), but one reason is so that I do not have to use them in a corner if I choose not to. Also, I really do not need a profesional grade speaker, I will be useing them for simple home use.
The Theater 7 corner will give you more sensivity, more bass extension and plenty of db's for home use. They are also cheaper and will allow you to try out that SET that you are talking about. Once you try the SET with a speaker like the Pi's it may just open up a whole new world for you. Hi sen speakers really shine with tube gear.
Previous Topic: Hi Honey I'm Home
Next Topic: Midwest Audiofest
Current Time: Mon Oct 05 08:47:58 CDT 2026
