Home » Sponsored » Pi Speakers » Horn Designs for brand X drivers
Couple of answers [message #40782 is a reply to message #40781] Sun, 30 March 2003 20:53 Go to previous messageGo to previous message
An infinite horn is just that - infinite. So you can't build it. Modeling it will show you what a finite horn of given shape and characteristics might approach if mouth size is sufficiently large, or if several are used in a group. Besides this, there are spatial constraints that you can model with the "ANG" field - 4π is free-space, and is what a horn will act like suspended in the air away from any boundaries. Half-space is a common configuration as it is what a single horn standing on the ground will act like. It is represented as 2π in the "ANG" field. Quarter-space is (1) π in the "ANG" field and it is the condition a horn will be in if it is against two boundaries, like on the ground and against a wall or paired with another similar horn. And eighth-space is shown as π/2 and it is what the horn will act like when placed in a corner.
As for a 20Hz horn, you have a problem if you want to truly horn-load the bottom octave. It has to be huge. So before you even worry about flare shape, you might want to set some design goals. If your goal is 20Hz f3, you're stuck with only options that are very large. One of my favorite solutions is to use room corners because they form the largest horn one can possibly fit in a room. Hyperbolic or exponential expansion loads the diaphragm lower than a linear expansion for a given length, but again, the room's corner is the biggest horn you can possibly fit into a room. So it makes a lot of sense to take advantage of it.
Previous Topic: 2 Pi Tower Review on enjoythemusic.com <nt>
Next Topic: Sub enclosure for 10" mid within bass cab.? Bmar? Wayne?
Current Time: Mon Oct 19 16:27:26 CDT 2026
