Home » Sponsored » Pi Speakers » Paramours and other goodies for LIMA
Re: Paramours and other goodies for LIMA [message #40772 is a reply to message #40744] Fri, 28 March 2003 16:23 Go to previous messageGo to previous message
Wayne,
If you're a tube-miser, you can install the C4S boards in a mirror fashion, as you only use one triode section in each driver tube with it. Adds about 15 min. to the short process. Theory is then you can swap the tubes in the monoblocks after one side starts to go...pins 4,5,&9 are heater, then pins 1,2, and 3 correspond to pins 6,7,&8 (i.e., the triodes run in opposite directions in the tubes). Probably not a big deal either way...
Glad to hear your experimenting...
Matts
Previous Topic: Question for Wayne Re: Paramour Parafeed caps with Pi Theater 4's
Next Topic: Alpha 6 and horn loading
Current Time: Sat Nov 28 22:35:08 CST 2026
