Home » Sponsored » Pi Speakers » room+corner horn,xmax,Fc questions
room + corner horn, xmax, Fc answers [message #40640 is a reply to message #40637] Fri, 14 March 2003 16:12 Go to previous messageGo to previous message
The π cornerhorn bass bin has a woofer mounted on a baffle facing the corner in near proximity. There is no compression and the rear chamber is slightly overdamped, making response conjugate the bass lift from corner placement. The π cornerhorn works very well this way and it's easy to build and service.
Another form of π cornerhorn or folded horn is one having a circular reduction plate "compression ring" in front of the woofer to increase compression above 1:1. The woofer is mounted on the baffle just as the 1:1 configuration, and a compression ring is placed over the woofer and held in place with the same mounting screws. So the throat area is determined by this first orifice.
And a third configuration for the cornerhorn is one that uses reduced size slots to form the actual throat. In this manner, the volume between the woofer and the side slots forms a sizable front volume, which is normally absent on the other two configurations. This allows more tuning paramaters at the expense of necessitating an access panel, making the design harder to build and service. However, some have built this configuration eliminating the slits entirely and used the space between the chamber and the walls as the throat. That gets around the requirement for an access panel.
The main feature of the π cornerhorn is that the horn flare is formed entirely by the listening room's corners, and there are no foldings within the cabinet. The cabinet serves only as the throat and a chamber for the woofer. It is a tuned chamber, so it allows some tuning but the horn flare is formed entirely by the room's corner.
One of my favorite software tools for simulating the cornerhorn or any other horn is McBean's Hornresp program. You will need to enter driver parameters and area expansion as a function of length. The profile is conical, and the area expansion is determined by the formula A=X230.5/4. Please see the post called "Cornerhorns" for more information.
Previous Topic: Till E. -- Passive preamp
Next Topic: Wayne, everyone: Happy Pi Day! n/t
Current Time: Fri Nov 20 14:01:21 CST 2026
