Home » Sponsored » Pi Speakers » anything lighter then MDF?
Re: anything lighter then MDF? [message #40624 is a reply to message #40623] Wed, 12 March 2003 16:27 Go to previous messageGo to previous message
Sure! Baltic, Russian or Finnish Birch. Expensive compared to regular ply or MDF. Worth it! REally excellent void free stuff. The laminations are so tight the exposed edges look good enough to finish without edge-banding.
Try to find a cabinetmaker that will order some for you. Enough 5X5 sheets to build the big Theatre cabs should run about $120 dollars.
Previous Topic: WOW, first time I've been AMAZED in a while.(long)
Next Topic: RCF N380 Compression Drivers for my JBL 2370A horns
Current Time: Mon Nov 16 09:10:21 CST 2026
