Home » Sponsored » Pi Speakers » B&C vs P.Audio compression drivers
Re: Nice choice! [message #40552 is a reply to message #40545] Thu, 06 March 2003 00:26 Go to previous messageGo to previous message
Kewl, I think I'll go with the SD-450 N then. In Australia, they are very well priced (which is nice for a change!), at AU$215, which converts to US$132. In the US I believe they cost a fair amount more.
I'll be sure to let you know how it sounds! Thanks for your advice! Adrian
I'm going to be buying mine from www.cannonsound.com.au but if you are not in australia then www.loudspeakersplus.com sells them, also www.speakercity.com but they dont have this model, they could probably get it in though.
Previous Topic: 10 Pi question for Wayne
Next Topic: Is there a good substitute for r13?
Current Time: Tue Oct 20 14:54:09 CDT 2026
