Home » Sponsored » Pi Speakers » B&C vs P.Audio compression drivers
Re: B&C vs P.Audio compression drivers [message #40544 is a reply to message #40533] Wed, 05 March 2003 14:20 Go to previous messageGo to previous message
Thanks for the advice!
I did notice the high reccomended cutoff of the B&C as well. I checked out the two P.Audio drivers you mention, the PA-D45 looks nice, with reccomend 1K xover freq. I am using the Pi Crossover, at either 800Hz or 1.6KHz (have not decided yet). I'm thinking that the PA-D45 is designed for PA use (hence the model number!) so it may sound like crap for Hi-Fi purposes? I did also look at the BM-D450, it looks nice too, but reccomened xover of 2.2K and freq range of 1.5K to 20KHz :( What do you think of the P.Audio SD line? The SD-450 N has fs=750Hz, and freq range of 500-20KHz. The freq response graph can be seen below:
http://www.paudio-europe.com/products/db_product.htm?v_tipo=2&v_tipo_desc=DRIVERS&v_num_series=13&v_des_series=SD-SERIES&v_id_art=284
I am not sure what horn this is measured on though. Maybe you can just let me know if you think its a worthwhile driver?
Oh ya, do you think titanium is the best for the diaphram?
Thanks for your help so far! Adrian
Previous Topic: 10 Pi question for Wayne
Next Topic: Is there a good substitute for r13?
Current Time: Tue Oct 20 16:13:20 CDT 2026
