Home » Sponsored » Pi Speakers » TEN PI Questions...
Re: TEN PI Questions... [message #40497 is a reply to message #40494] Mon, 03 March 2003 15:11 Go to previous messageGo to previous message
Shanko is currently offline  Shanko
10Pi's are hard enough to move as it is. If you filled the voids with sand, you would need a crane.
Maybe what you could do is fit rubber bungs in the side of the cab for the top and bottom spaces. Move the speaker into position, and then funnel the sand in. If you wanted to move them later, you might be able to tip them over (with a lot of help) and tip out the sand.
Have you got strong floors? This sort of treatment could get 10Pi's sounding even more 'solid'.
Previous Topic: tube active crossover LISTENING TESTS
Next Topic: Which pi has the "most" bass?
Current Time: Tue Oct 20 20:44:59 CDT 2026
