Home » Sponsored » Pi Speakers » tube active xover update
TEMPORARILY lifted the green wire from chassis [message #40475 is a reply to message #40474] Sat, 01 March 2003 20:08 Go to previous messageGo to previous message
and hum voltage measured at the outputs dropped dramatically. I think it might be asking for loop problems, sticking a chassis that is earth grounded, into the signal chain where the preceding and following units are 2 wire/isolated. If it is quieter in the system, I'll try RECONNECTING the earth ground, and look into "floating" the neg. end of the B+ supply filter caps and signal grounds from the chassis. The marchand isolates all signal and power grounds from the chassis, and connects the p/s ground to earth via a resistor, FWIW.
BTW, at the outlet my ac line neutral and earth ground have about 0.3vRMS differential...is that "normal"?! Sam
Previous Topic: Diaphram size of compression drivers, does it affect performance?
Next Topic: Nice quiet jazz night at home tonight!
Current Time: Sat Nov 14 15:42:38 CST 2026
