Home » Sponsored » Pi Speakers » Re: Pi Speakers
Re: Pi Speakers [message #40466 is a reply to message #40461] Sat, 01 March 2003 08:25 Go to previous message
Since I assume you're referring to the reflex opening the answer is yes, you can place it on the backside of the box if you wish. Just be carefull that nothing blocks it - there have to be 3-4" of free space behind the speakerbox, or else the speaker won't operate proberly in the bass. Same goes for inside the box, btw. - no damping material must block the opening.
Previous Topic: Does the JBL 2370 HORN use screw on or bolt type mounting???
Next Topic: Diaphram size of compression drivers, does it affect performance?
Current Time: Sat Nov 14 15:42:37 CST 2026
