Home » Sponsored » Pi Speakers » Does the JBL 2370 HORN use screw on or bolt type mounting???
Re: Standard 3-hole bolt-on mount [message #40433 is a reply to message #40431] Thu, 27 February 2003 04:46 Go to previous messageGo to previous message
Hey, thanks for the info. I just hope the 2370 is the 2370A! Im not actually sure if the one I'm ordering is the A version or not, if it isn't though, would it be safe to bet that theres little difference between the two? Thanks! Adrian
Previous Topic: One Pi/Two Pi driver level adjustment?
Next Topic: Re: Pi Speakers
Current Time: Sat Nov 14 15:54:15 CST 2026
