Home » Sponsored » Pi Speakers » Pi 10 build idea
Re: Pi 10 build idea [message #40412 is a reply to message #40406] Mon, 24 February 2003 10:57 Go to previous message
I like the idea of a horn that can be disassembled, but the problem is always how to make such a device that won't rattle and buzz when being used. There is a lot of power generated by these things, and even the solid model is tough make buzz-free. Any large format bass or midbass horn is going to vibrate its panels with great force. So just be sure to brace them well, use clamps that won't buzz and put rubber gaskets between each section.
Previous Topic: PI's and amps
Next Topic: P.Audio SD-450 N on JBL 2370 Bi-Radial Horn with Wayne Parhams compensation circuit
Current Time: Mon Oct 05 11:59:38 CDT 2026
