Home » Sponsored » Pi Speakers » P.Audio SD-450 N on JBL 2370 Bi-Radial Horn with Wayne Parhams compensation circuit
2370 caps [message #40407 is a reply to message #40398] Mon, 24 February 2003 07:19 Go to previous message
Yes the .33 0r .22 is for the bypass, and the standard value works ok too, but with 2370 when you play loud it sounds splashy with .47. The mF uF thing was just a typo on my part, oops. The best thing would be to get all three of the cap values and then see which one you like with your compression driver, as it can be a matter of taste as well as science. As for cap types, I like any film and foil caps. the Auricap is nice, but any audio grade film and foil type would do fine. If you have trouble getting them, go for metalized film caps as a second choice. The brand is no big deal so long as they are made well and accurate.
Thomas
Previous Topic: Pi 10 build idea
Next Topic: 10 Pi Plans
Current Time: Thu Nov 19 10:08:08 CST 2026
