Home » Sponsored » Pi Speakers » P.Audio SD-450 N on JBL 2370 Bi-Radial Horn with Wayne Parhams compensation circuit
Re: Radial horns [message #40397 is a reply to message #40389] Sun, 23 February 2003 23:40 Go to previous messageGo to previous message
Hey Wayne. Would you say then I should use a 1" driver crossed like 2Khz then, and use a horn loaded 8" that bmar (Bill/Martinelli Sound guy) suggested in the other post? Or do ya think it is not really necessary?
> better crossover below 200Hz
I'd assume not with the compression driver ?? !!!!!!!
Is there any sonic differences between plastic/ABS and metal horns?
Probably said this a million times, I'll say it again though lol you've been a big help so far and thanks for your time.
Adrian
Previous Topic: Pi 10 build idea
Next Topic: 10 Pi Plans
Current Time: Thu Nov 19 10:09:20 CST 2026
