Home » Sponsored » Pi Speakers » P.Audio SD-450 N on JBL 2370 Bi-Radial Horn with Wayne Parhams compensation circuit
Re: Radial horns [message #40383 is a reply to message #40382] Sun, 23 February 2003 01:58 Go to previous messageGo to previous message
You can array these horns vertically, in fact, I believe they publish polar charts of a vertical array of 2370's. That would help to improve vertical pattern control at low frequencies. The reason it does this is off-axis interference nulls form because of interaction from adjacent horns.
Don't rotate the horns because that would give tall vertical coverage and narrow horizontal coverage above through most of the passband, above about 2kHz. Below that, the pattern changes because of mouth diffraction. Essentially what is happening is that the horn's mouth forms a diffraction slot, so pattern widens at low frequencies. Since the vertical dimension is short, directivity control is lost along this axis first. Below about 1kHz, vertical dispersion of a single horn is actually wider than the horizontal pattern.
Previous Topic: Pi 10 build idea
Next Topic: 10 Pi Plans
Current Time: Thu Nov 19 10:09:36 CST 2026
