Wayne Parham Messages: 19108 Registered: January 2001
That would probably be just fine - Certainly the volume is correct. But I'm a little concerned about having both the width and the depth equal. The frequency of this wavelength is 1125Hz, so it might make vocals a bit odd if this overtone generated standing waves inside the cabinet. I suggest that you break it up by making one of the two dimensions a half-inch smaller and the other a half-inch larger.
