Home » Sponsored » Pi Speakers » Impedance peak
Re: Impedance peak [message #40349 is a reply to message #40348] Wed, 19 February 2003 11:44 Go to previous messageGo to previous message
An impedance peak of 13 ohms isn't terribly high, and is expected from a horn. There will be a few peaks near the flare frequency and its harmonics. There are also sometimes peaks caused by diaphragm mechanical resonance below the flare frequency, where the horn cannot load the diaphragm. To tame these peaks, and electrically mnatch the driver better with the crossover, I suggest you use a shunt resistor damper. Please see the π Crossover Document for more information.
Previous Topic: What is your tolerance for background noise
Next Topic: Hi Wayne: Wooden Horns
Current Time: Thu Nov 26 11:56:43 CST 2026
