Home » Sponsored » Pi Speakers » three Pi kits
Re: You've got mail! [message #40145 is a reply to message #40142] Tue, 04 February 2003 13:52 Go to previous messageGo to previous message
massappeal85 is currently offline  massappeal85
Sorry about that. Another email adress is at the bottom. I actually have a couple more questions.
I'm going with the Theaters cause I need something that can handle a 250w amp. Somehow I'm under an impression that some HT speakers are voiced differently for movies, but I'll only use these for music. Will these be just as fine with music as are your other speakers?
Second, the three pi and four pi have different sized woofers. The speaker guide on eminence's website says the Delta 12LF is good for being a subwoofer while it implies the delta 15 isn't as suited. Can I expect the same or more bass output from the four pi as the three pi?
If you could send me the FOUR theater pi plans instead of the threes, that'd be great. The email is lrapter@adelphia.net
Thanks so much for your time.
Previous Topic: a small update
Next Topic: Plywood vs. MDF
Current Time: Thu Nov 19 16:47:53 CST 2026
