Home » Sponsored » Pi Speakers » 16 ohm L-pad information needed please!
16 ohm L-pad information needed please! [message #40088] Thu, 30 January 2003 08:29 Go to previous message
Mikey is currently offline  Mikey
Hi Guys,
My high efficiency speaker system has evolved into a two-way setup using a 15" Gauss 4580A on the bottom, augmented by a JBL 2446J on the top end. Crossover frequency is 500Hz.
The JBL crossover consists of (in order, from input jacks to speaker terminals):
- 12 dB rolloff using the appropriate cap and coil
- a Parts Express 260-261 16 ohm L-pad (see link below)
- impedance compensation
- CD equalization
My question centers around the L-pad I'm using....
Now that I've got the levels matched between the Gauss and the JBL, I plan on removing the cheesy rotary pot and replacing it with Mills resistors of the appropriate value. Without disturbing it, I removed the pot last night to measure the equivalent values of R1 (series resistor) and R2 (parallel resistor), and came up with the following:
R1 = 6.0 ohm
R2 = 5.5 ohm
Just for kicks, I decided to verify these values with the formulas found in Vance Dickasons Loudspeaker Cookbook. It turns out that they were way different! According to his formulas, a R2 of 5.5 ohm should calculates to a R1 of 12 ohms!
Should I just ignore the theoretical values and replace the pot with the values I measured? If not, can anyone help me with the proper calculations for this L-pad?
Thanks in advance,
Mike
Previous Topic: Pi Theater 4s at Outdoor Wedding Reception
Next Topic: Has anyone tried the SELENIUM 15PW3CE? looks smoother than emm.
Current Time: Tue Nov 03 22:39:52 CST 2026
