Home » Sponsored » Pi Speakers » Tweeter 1/2" to low :(
Odds and ends [message #40084 is a reply to message #40078] Wed, 29 January 2003 00:14 Go to previous messageGo to previous message
You're right - the wire with the spool should be attached to the midwoofer. Be sure that the lead positive lead of your connector panel is connected to the positive lead of your tweeter and also the positive lead of your midwoofer, through the inductor. I forget if your kits have the inductor that would be screw mounted or not - If you have a hole on the spool that would fit a small screw, us that to attach the coil to the inside back wall. If not, use automotive weatherstrip glue.
Previous Topic: Theater 4pi audition
Next Topic: Pi Theater 4s at Outdoor Wedding Reception
Current Time: Wed Nov 04 01:38:00 CST 2026
