Home » Sponsored » Pi Speakers » Help picking right speaker
10Pi with Theater parts - No Go [message #39980 is a reply to message #39976] Tue, 21 January 2003 12:35 Go to previous messageGo to previous message
When using different woofers, one should expect to use a different motor chamber. Often times, a different horn should be used too. Also, some drivers don't do so well in horn enclosures. If a woofer or midwoofer has very low Q, for example, I would expect it to work poorly at the lowest frequencies in a bass-reflex or sealed cabinet but do well in a horn. And if it has very high Q, I would expect it to work poorly in a horn, but do well as a direct radiator on a baffle or very large box.
I really like the JBL 2226 in the ten π horn. It extends its low frequency limit because of its behavior at the flare frequency. And it allows the driver to be used much higher than other folded horn designs, acting similarly to a straight horn in many respects. I would expect other similar drivers to work well in this cabinet, but there are also some that probably wouldn't work so well. As long as Vas and Qts are reasonably close, you'll probably be fine.
But the Delta 15 used in the Theater Series four and seven π should not be used in the ten π in my opinion. They sound great in a π cornerhorn and they work well in a bass-reflex box. But I don't like them in a folded horn - With a Qts of 0.5, they're just too boomy in a ten π. This isn't an issue in the π cornerhorn, because it acts like an infinite horn, so that's a nice solution instead.
Previous Topic: Acoustic reflection from the edge of the horn-mouth
Next Topic: Impedance curves for Eminence Woofers?
Current Time: Mon Nov 02 07:40:29 CST 2026
