Home » Sponsored » Pi Speakers » How many of you have "Soular Energy"? Hands?
be george, he's got it! [message #39871 is a reply to message #39867] Mon, 13 January 2003 04:50 Go to previous messageGo to previous message
Ron,
Good call on the crossover still seeing about the same load, even with the higher driver impedance. Are you using a R2 of 16ohms, and R1 of 25ohms, a la 12dB Pi Pad? Then substituting the higher z driver will likely reduce the attenuation present by maybe(?) 1.5dB's...you could probably "correct" for the difference by increasing R1 to 30 ohms. Otherwise, your HF MAY be a little hot. Sam
Previous Topic: 2Pi Speakers
Next Topic: Woofer-tweeter
Current Time: Mon Nov 02 04:30:18 CST 2026
