Home » Sponsored » Pi Speakers » Woofer-tweeter
Re: Woofer-tweeter [message #39864 is a reply to message #39863] Sun, 12 January 2003 12:52 Go to previous messageGo to previous message
To attenuate a piezoelectric tweeter, use a capacitor in series. Since the tweeter is primarily capacitive, a series capacitor forms a voltage divider rather than a frequency splitter. There is no filter function when components having the same reactive properties are connected together. So a capacitor/capacitor network forms a simple voltage divider, much like a resistor/resistor network does.
For a KSN-1038, you can expect attenuation in the following amounts:
1.0uF 1dB
0.5uF 2dB
0.33uF 3dB
0.22uF 4dB
0.1uF 7dB
These values are what you'll get if you connect a capacitor in series with the tweeter, and do not use any other components. That gives broad-band attenuation only, and does not act as a crossover.
See the post called "Pi implementations of quartz piezoelectric tweeters"
Previous Topic: How many of you have "Soular Energy"? Hands?
Next Topic: Let's try those 2Pi Towere pictures again.
Current Time: Mon Nov 02 02:24:33 CST 2026
